[Mi...] Posted February 20, 2025 Share Posted February 20, 2025 Hallo zusammen, ich muss an einem Bauteil eine Nut rundherum vermessen, was über Freiformfläche einfach zu messen ist. Allerdings hatte ich noch nie eine solche Toleranzangabe mit UZ (siehe Bilder) Was muss ich hier bei der Toleranzform (roter Kreis) auswählen? Für jede Antwort wäre ich sehr dankbar. Gruß Mirco Link to comment Share on other sites More sharing options...
[Ma...] Posted February 20, 2025 Share Posted February 20, 2025 Hi Mirco. You should use bilateral with unequal distribution. For tolerance use 0.1 and for tolerance for one side use 0.0 and click that icon to show dimension from center to out of material ( or use 0.1 and dimension from center to material ) If you are in doubts use graphical evaluation to see it visually. This callout can be translated as that groove should be from nominal size or max bigger by 0.1mm per side. Or like hole ⌀30 +0.1/-0.0 and same for depth ( 10 +0.1/-0.0 ) 1 Link to comment Share on other sites More sharing options...
