Looking at Measurement Series Script
Hello all,
I was wanting to view a python script for a measurement series for scans M1,M2,M3..... I know that you cannot access or move the scans around within the explorer. Is there a script within ZEISS Inspect that will allow me to view those scans within the measurement series?
Some things I have tried:
I looked in the cache folder and couldn't find the script there
I recorded the script when I ran my scan, but it did not record the actual measurement series only the rotation table values I placed.
I went into the Add-On editor and went -> Insert->Element Value. But that is still not what I was looking for
The only other thing I can think of is to create my own python script to be able to retrieve those scans and put them into an array. Any guidance would be appreciated
I was wanting to change the order of the scans and to be able to look at the angle measurements for each series. I know you can look at the angle measurements in the explorer. Overall, I was just curious as to where those scans are stored other than the explorer
  • 3 weeks later...
you can re-order scans within a measurement series with cut / paste.
What angles are you referring to? Teaching parameters?
