PCM/PiWeb report folder creation
Is there a way to create a folder based on a user variable when auto saving the reports?  If so, what syntax would I have to put in the pdf settings? I'd like to have the report saved in a folder based on the Job number to keep them organized.
Edited
More context
  • Like! 1
there is probably a better way to do this, but one way is like this
after i put in the directory, i chose "order" in the report header fields. this is the folder that gets created by the user input. afterward, you manually type:
im not 100% sure on how it works, but i believe that is what makes the "order" user input be created as a folder. afterward i put in another variable which is what it saves the files name as, and then file ending.
this menu is under "measurement" "multiple report" then the 3 dots right under "output media for cnc run"
i also only use the default presentation report instead of piweb so i have no idea if this also works for piweb, but i hope this helps.
  • Like! 1
  • Thank you! 1
Sort of, you can set any recordhead variables you wish, and use them. Eg:
normalVar = getActual("something").x
setRecordHead("mySneakyVar",normalVar)
"c:\path\"+getRecordHead("mySneakyVar")+"\..."
Well you get the point....
  • 3 weeks later...
