[Ed...] Posted February 24, 2025 Share Posted February 24, 2025 Hello, I need to measure a hole overlapped by other holes. I want to measure de most top hole but the system only recognize the middle one. Any ideas on how to solve this? Link to comment Share on other sites More sharing options...
[Ja...] Posted February 24, 2025 Share Posted February 24, 2025 Hi , grey value principle will not work here. This principle is for features punched through single sheet metal where the edges of the metal are too thick to scan. As this hole has some depth then the strategy will be to scan the cylinders and most likely create an offset section to measure the appropriate diameter Link to comment Share on other sites More sharing options...
[Ge...] Posted February 27, 2025 Share Posted February 27, 2025 We use threaded adapter tools from Witte, that can be either threaded to capture the pitch diameter of the threads or solid to locate off the minor diameter, we order them with a "matte" finish for scanning. Link: Fixinspect-Katalog-Control-WKG-EU-04-2023 Link to comment Share on other sites More sharing options...
[Ge...] Posted February 28, 2025 Share Posted February 28, 2025 Sorry, ignore my reply, I misread the OP, thought you wanted to measure the threaded hole. Link to comment Share on other sites More sharing options...
