How to access System Detail Pages
So on a regular piweb report you can right click on a characteristic and it will bring up the attached charts, I really like the "machine capability" chart and would like to have it generate every time instead of having to manually generate and save it. Is that possible? I am not seeing any of these options on the typical report list.
I also don't see a way to edit or copy these over into other reports, that would be a sufficient option.
I believe that the .PTX files that you want are located here: C:\Program Files (x86)\Zeiss\CALYPSO 7.6(or whichever version you have)\bin\PiWebReporting\defaults\DetailPages
You may have to do some light editing to the data bindings of these files, but otherwise they should be good to go.
