Measurements between sheets - two cutting lines
  • 2 weeks later...
Hi,
If this is a sheet metal application, I would suggest measuring your part using Gray Value Features.
Once this is measured, define nominal edge curves on the CAD model of your part where you would like take the measurement.
Give those edge curves the measuring principle: Gray Value Feature.
To create your evaluation you can use either the 2-Curve Distance or Continuous Curve Distance functions:
This should give you what you are looking for.
