[Ed...] Posted February 26, 2025 Share Posted February 26, 2025 (edited) Hi, I have this callout of profile of line for internal diameter (REF-A), this is ISO. Could someone please explain how can I measure this profile of line? Does it mean that every 10mm I need to be within 0,005mm of line profile? Do I need curve for this? BR Edited February 26, 2025 Link to comment Share on other sites More sharing options...
[Ma...] Posted February 26, 2025 Share Posted February 26, 2025 (edited) I am not sure if this can be done on newer versions of Calypso - but it should work same as flatness with ref. - so any 10mm part should fit in profile callout ( +/- 0,0025 ) If it's diameter ( circle/cylinder ) then there is basic dimension for diameter/radius so you have to use profile callout, which allows only curves. But you possibly may use "Form" with locked/restricted radius and maybe doubling result ( profile callout is max deviation*2 ) Edited February 26, 2025 Link to comment Share on other sites More sharing options...
[Ed...] Posted February 26, 2025 Author Share Posted February 26, 2025 Please sign in to view this quote. Thank you, At least I can tell to managers that I need a curve 🙂 Link to comment Share on other sites More sharing options...
[Za...] Posted September 4, 2025 Share Posted September 4, 2025 Below is a link to an article with a way in which profile can be satisfied without the use of a Curve license. Use cases are limited however. https://portal.zeiss.com/knowledge-base?id=2495545 1 Link to comment Share on other sites More sharing options...
