[Ch...] Posted February 27, 2025 Share Posted February 27, 2025 Is it possible to import .zmp files into Piweb from a Calypso idmeaspoints folder? Can an import template be created for this? I see the .zmp files are compressed and can be decompressed into files. I do not know what file format this is for example: scbada 1 13 1313 scbada 1 531 2 x -110.37508477046 -95.61497655784 216.69672500026 x -110.36993605644 -95.61422961362 216.69714427022 My current method is to load into Calypso manually and run offline. It happens where Calypso has under "Results to file" the radio button for PiWeb Export activated but the check box for PiWeb Export in the Run screen becomes un-checked. I do not know when or why this occurs. It appears random. I open Calypso , toggle radio button and save. This fixes the problem for a while. CALYPSO 2019 , ServicePack 6, PiWeb 6.8.7.0 Link to comment Share on other sites More sharing options...
[Do...] Posted March 25, 2025 Share Posted March 25, 2025 No, the *.zmp files cannot be directly imported into PiWeb. In Calypso, either the PiWeb Export (old) or PiWeb Reporting (new) interface must be used to upload the data to the PiWeb server. With your version of Calypso, you need to use the PiWeb Export. The Calypso interface can be installed on the Calypso computer using the PiWeb installation file. Link to comment Share on other sites More sharing options...
[Ch...] Posted April 11, 2025 Author Share Posted April 11, 2025 Thank you for the response. It was a shortcut idea I had to solve a problem. Link to comment Share on other sites More sharing options...
[Ch...] Posted September 17, 2025 Author Share Posted September 17, 2025 Calypso/ Plan / Subsequent evaluation of several measurements This helps me recover from the failure to upload data to PiWeb issue. I appreciate the self indexing run and serial number feature. Link to comment Share on other sites More sharing options...
