[Lu...] Posted February 28, 2025 Share Posted February 28, 2025 Hello, Is there a way to set a program to not default to "Manual Alignment?" I want it to default to the automatic alignment, so when I click Run I do not need to change the dropdown from "Manual Alignment" to the automatic alignment. Thank you Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/ Share on other sites More sharing options...
[To...] Posted February 28, 2025 Share Posted February 28, 2025 Please sign in to view this quote. In the Base Alignment window, un-tick the Manual Alignment option. Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/#findComment-127445 Share on other sites More sharing options...
[Ma...] Posted February 28, 2025 Share Posted February 28, 2025 You can tryout menu -> CNC -> Preassign CNC Start Values - this will bring same window, but any other starts will be using new setup. Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/#findComment-127447 Share on other sites More sharing options...
[Cl...] Posted February 28, 2025 Share Posted February 28, 2025 (edited) After you've established the starT alignment and the CMM now knows the location of the fixtured part. Tick Base Alignment Choose the base alignment from the drop-down. It will not begin with the BA. Edited February 28, 2025 Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/#findComment-127449 Share on other sites More sharing options...
[Lu...] Posted February 28, 2025 Author Share Posted February 28, 2025 (edited) I tried these ideas...no luck. Most of these suggestions seem to be a different version of Calpso. I found Plan -> Assign CNC Start Values. I thought that would work but it didn't. Edited February 28, 2025 Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/#findComment-127499 Share on other sites More sharing options...
[Ma...] Posted March 1, 2025 Share Posted March 1, 2025 For new programs this can not be set. Autorun with pallet has it's own settings. Once you make changes, this will be set until next manual change. Template won't work either Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/#findComment-127503 Share on other sites More sharing options...
[Da...] Posted March 1, 2025 Share Posted March 1, 2025 22603-set-default-alignment-run-menu.bmp Please check the base alignment setting 'Manual Alignment' Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/#findComment-127517 Share on other sites More sharing options...
[To...] Posted March 3, 2025 Share Posted March 3, 2025 (edited) Does it run the base alignment in CNC mode after you do the manual alignment? Or, does it make you manually align it a second time? If the latter, go into Features Setting Editor, find the CNC settings. I'm guessing the features in the BA have been set to Manual. If so, change them to CNC. Edited March 3, 2025 Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/#findComment-127567 Share on other sites More sharing options...
[Da...] Posted March 3, 2025 Share Posted March 3, 2025 Link to comment https://qualityforum.zeiss.com/topic/22603-set-default-alignment-run-menu/#findComment-127575 Share on other sites More sharing options...
