[Ni...] Posted March 1, 2025 Share Posted March 1, 2025 Hello, First time posting here, I hope I'm doing everything right. I have a problem with cluster creation (Zeiss Inspect 2025.1.0.1985). Everything works fine when I have one part (picture 1). I can create and copy a cluster with no issues. As soon as I add another part (doesn't matter if it's empty or not) I can no longer create a cluster and I get this message (picture 2). I haven't found a workaround for this issue because no matter what I select I get the same "Please select nominal element" message. Is this a bug or am I doing something wrong? I need to add another part because I want to inspect a digital assembly of two separate scans. I'm taking references from one scan to measure features on another scan. I need to use clusters because in total there are around 300 measurements. Any kind of help would me much appreciated! Thanks! Link to comment https://qualityforum.zeiss.com/topic/22609-create-cluster-only-works-when-i-have-just-one-part/ Share on other sites More sharing options...
[Se...] Posted March 3, 2025 Share Posted March 3, 2025 Hello Nikola, This is a bug that will be solved in the next software release (Service Pack 1) For a solution for this particular case until the release, more details would be needed. At best contact support for this. Sergio Link to comment https://qualityforum.zeiss.com/topic/22609-create-cluster-only-works-when-i-have-just-one-part/#findComment-127531 Share on other sites More sharing options...
