PCM command for the modification date of a file
Hopefully this is what you are looking for!
With a few edits, can output the data however you want. The below will just output in a display window.
// Path to your file as a String, can be any file (OR folder!)
file = "C:\Path\To\Your\File\example.txt"
// Modified Date
display("Modified Date: ", file.asFilename.dates.modified.first)
// Modified Time
display("Modified Time: ", file.asFilename.dates.modified.second)
//          Bonus
// Accessed Date
display("Accessed Date: ", file.asFilename.dates.accessed.first)
// Accessed Time
display("Accessed Time: ", file.asFilename.dates.accessed.second)
// Created Date
display("Created Date: ", file.asFilename.dates.created.first)
// Created Time
display("Created Time: ", file.asFilename.dates.created.second)
file="C:\Temp\test.txt"
file.asFilename.creationTimestamp
file.asFilename.modificationTimestamp
Thank you both very much for your replies.
Now i get the month as a string.
Is it possible to get the date format only in numbers, or the as the amount of days as in:
date(1).asDate.asDays
Thank you.
Yep, it's possible.
For Instance:
date=file.asFilename.dates.created.first
or
date=file.asFilename.creationTimestamp
// date in Numbers:
date=date.dayOfMonth.asString + "." + date.monthIndex.asString + "." + date.year.asString
