Concentricity vs Coaxiality
Would you consider this Concentricity? or Coaxiality? We are having a difference of opinion on this.
Concentricity describes how close the axis of two cylindrical or circular features are to each other. IMHO.
If the length of the cylinder is longer than 3 times the diameter, it is evaluated in terms of coaxiality.
If the length is shorter than 3 times the diameter, or if there is an ACS symbol, it is evaluated in terms of concentricity.
  • Like! 3
Can you offer a paragraph from international or national standard supporting the 3 times statement?
I do not understand the difference between coaxiality and concentricity in your case ?
I this case, I prefer check straightness of the 2 axis in combined zone because the datum A is too short.
Concentricity applies looking down the center axis, coaxiality applies when looking at it from the sides.
I am not an ISO expert in any regards, but I am looking forward to the comments from the ISO community on the ACS interpretation.  I also don't understand why ISO coaxiality doesn't consider the outer tangential element condition of the considered feature.
I'm in the same boat. As described, it looks like they are process controls more than anything else...
Thanks a lot for this video ! Never seen the ACS symbol 🙂
Unfortunately, there is no paragraph in the international standard that implies 3 times.
This is an unwritten law which is applied in a sensible way in terms of measurement technology🤓
  • 1 month later...
Hello, on your plan it's a coaxiality, it depends how it is draw on your plan.
Exemple:
