Window « Open Calypso measurement plan window
Hello,
In our company, we have a Contura G2 with Calypso 7.6. A colleague was performing some measurements and accidentally closed the 'Open Calypso measurement plan' window. Since then, we haven't been able to open it again. This window is very useful because it eliminates the need to manually search for programs, ultimately saving us time.
Does anyone happen to know how to reopen it?"
If one would like to disable the window you can “Right Click” > Don’t show favorites again. To undo this setting delete the CALYPSOFileDialog.exe folder located at C:\Users\<USERNAME>\AppData\Local\Carl_ZEISS_Industrielle_M (Note: AppData is a hidden folder, double check that you PC is set to View > Hidden Items.)
https://portal.zeiss.com/knowledge-base?id=1444152
