Stylus/Probe files
Calypso creates pcf files, you have to export each one to save them.
Go to (Your path may be simialr):
C:\Users\Public\Documents\Zeiss\CALYPSO 7.4\config\equip
Then look for your CMM name (Tab name when you connect to the CMM).
The saved pcf files should end up in that location.
A short cut to the location:
Export a stylus for saving, then in the address bar copy that URL.
All the stylus information is stored in the config folder (C:\Users\Public\Documents\Zeiss\CALYPSO 7.8\config), more specifically, as Richard pointed out, the equip - CMM folder. However, if you're looking to make backups or transfer between versions, I would recommend backing up the entire config so it also backs up/transfers all of the user settings/machine information which is also saved in the config.
Just as further information, if you're interested in where other information is stored, this article shows where a lot of the information in CALYPSO is stored and how to move it between CALYPSO versions/computers: https://portal.zeiss.com/knowledge-base?id=444235
