create circle/ellipse
Hello
Do you have a point cloud?
Maybe you can go to Construct menu, select circle, and a fitting circle, after you select the points to construct a circle.
This information can not be enough for you, it depends if you have information enough to construct a circle or not.
, you need to create a 2D section first in order to fit 2D elements like cylinders and ellipses.
You should go under Construct->Section-Single Section to create the section cut.
On that section you will be able to fit the geometry that you are interested in.
Edited
