[FL...] Posted March 17, 2025 Share Posted March 17, 2025 I was wondering how i can delete all user settings and return everything back to default. Same for any other settings. Thanks, Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/ Share on other sites More sharing options...
[Na...] Posted March 17, 2025 Share Posted March 17, 2025 Hello, which software are you referring to? Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128423 Share on other sites More sharing options...
[FL...] Posted March 17, 2025 Author Share Posted March 17, 2025 Calypso Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128431 Share on other sites More sharing options...
[Ri...] Posted March 17, 2025 Share Posted March 17, 2025 P.S. I would like to know this as well. One employee left and everything is "his" preference. v2022 Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128433 Share on other sites More sharing options...
[Je...] Posted March 17, 2025 Share Posted March 17, 2025 C:\Users\Public\Documents\Zeiss\CALYPSO\config Delete (or rename to config_old). Restart CALYPSO. Starts like a FRESH install. FYI - this is where you machine info and probe data are stored as well. Each of the "values" files are where the settings are stored in the subdirectories. Your machine tabs and probe data live in the "equip" folder. This can be migrated to a new config folder. Import the "tab" by creating a new tab in CALYPSO with the same exact name. SQL MUST BE OFF. I advise doing a fresh PC restart as the easiest way of ensuring this. If you get a file-sharing error when modifying/copying a config folder, DO NOT IGNORE. The file that it is warning you of is your probe database. Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128451 Share on other sites More sharing options...
[FL...] Posted March 17, 2025 Author Share Posted March 17, 2025 Thanks Jeff! How do I turn off SQL? Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128459 Share on other sites More sharing options...
[Ma...] Posted March 18, 2025 Share Posted March 18, 2025 Good Morning, within the Installer of CALYPSO 2017-2023 you find a ClearSQL.exe, the folder can vary with each version but you find it within the SQL Installation files. Just run the ClearSQL.exe and it will cut the connection to the CALYPSO Database. For example CALYPSO 2023: Best Regards Marcel Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128467 Share on other sites More sharing options...
[FL...] Posted March 18, 2025 Author Share Posted March 18, 2025 Please sign in to view this quote. Marcel, I dont see ClearSQL.exe. The only thing i see is the Install.exe Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128485 Share on other sites More sharing options...
[Ma...] Posted March 18, 2025 Share Posted March 18, 2025 Hi FLTRXS, then you probably have CALYPSO 2024, its not included in this Version. I try to attach it in here but its an .exe file which might not work. Best Regards Marcel ClearSQL.exe Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128487 Share on other sites More sharing options...
[Ri...] Posted March 18, 2025 Share Posted March 18, 2025 Please sign in to view this quote. First and foremost, exit and terminate Calypso. Open Task Manager and go to Services. Look for a file named "MSSQL$SDCO", "Stop" the service and follow Jeffs instructions. When completed, restart the "MSSQL$SDCO" service. Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128541 Share on other sites More sharing options...
[FL...] Posted March 19, 2025 Author Share Posted March 19, 2025 Please sign in to view this quote. Jeff, I deleted the config file and restarted calypso, everything is new. How can I get the machine out of simulation, see pic_1. Once I configure the machine, probe and qualify master probe will it then get out of simulation? Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128635 Share on other sites More sharing options...
[FL...] Posted March 19, 2025 Author Share Posted March 19, 2025 Please sign in to view this quote. what it looked like before, see piuc_2 Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128639 Share on other sites More sharing options...
[Lu...] Posted March 19, 2025 Share Posted March 19, 2025 Hello, You'll need to create a new machine tab. This will allow you to uncheck the simulation only option and connect to your machine. KNOWLEDGE BASE ARTICLE Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128647 Share on other sites More sharing options...
[FL...] Posted March 19, 2025 Author Share Posted March 19, 2025 Please sign in to view this quote. Thanks for the info. I tried following it, but the ADD button is greyed out Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128665 Share on other sites More sharing options...
[Lu...] Posted March 19, 2025 Share Posted March 19, 2025 Please sign in to view this quote. Hit the ENTER key. Link to comment https://qualityforum.zeiss.com/topic/22773-user-settings-and-default-settings/#findComment-128667 Share on other sites More sharing options...
