Using notepad to edit program information quickly.
I want to edit these circled boxes quickly by edit with notepad instead of opening each program and do it from there. Which files from the program folder to open and edit?
Do this only if you know exactly what you're doing. Some  strings appear more than once in those files and you need to know exactly which one is the right one to edit. Otherwise you could get into trouble.
Modify only through the CALYPSO GUI or via PCM for relevant items.  It is STRONGLY advised that you do not interact with supporting files directly to modify output.
So it's not that simple to do. I have lots of programs that needs to be changed but on second though could caused issues if all the relevant string hasn't been changed.
 what i would do is make copy of program before change, then open and edit program through Calypso and save changes.
Now compare changes in files - you will see what has changed ( i hope only that text and nothing more )
