Flatness, can you specify minimum surface coverage using a CMM?
To our GD&T gurus, when flatness is called on a surface is there a way to specify minimum surface coverage when scanning?
We do have a "Tropel flatness machine" but the surface must lay on the glass to be scanned, recessed surfaces cannot be used on the system.
Not guru speaking, I just saw it by accident 🙂 - if you have access ISO 1101:2017, there are few options explained in paragraph 9.1.3 quite good.
But I don't want to paste screenshots publicly.
