Impossible to get trail version
Hi ZD,
As Christine mentioned, this is typically a login issue. Please ensure that you fully close the Zeiss Quality Suite and check that there are no tasks related to ZQS running in the background.
Next, I recommend clearing your browser cache. After doing that, reopen the suite, log in, and attempt the trial from within the suite. If you encounter any issues, try using the link you posted; I was able to access it successfully this morning.
Best regards,
Hi Kyle
I have followed your instructions: logged out from suite, cleared the browser cache, removed any task related to ZQS from windows task manager and this time I got this message as below. I tried both ways but neither directly from ZQS nor from browser it turns to the same error. What else can be wrong?
As mentioned in the screenshot a company email adress is required to get a trial/ free license.
If thats the case ZEISS ID musst be checked therefore get in contact with ZEISS via the contact adress or ZEISS ID.
Hi
I don't have a company email address because I don't have a company. I'm hobbyst of 3D scanning/measurment inspections.I was using/learning Optical Inpect in my free private time to get knowledge about it. Few days ago I got response from customer service that the global (non proffesional) emails like xxx@interia.pl or even xxx@gmail.com will not be supported to get registration to ZeissID portal.
My questions are : 1. Why hobbysts/ enthuisasts (with non proffesional email addresses) are abandoned to get the knowledge about Zeiss software? 2. Why my non professional email address is utilized by Zeiss spreading the newsletters- this politics seems to me contradictory and inconsistent, don't you think?
What else to do: 3. estabilish my own company with proffesional emial address? 4. How can I change in my user profile the non professional emial address if it's already grayed out (not editable anymore)? Please help me out/suggest something. Am I the only person how has this issue?
  • Like! 2
Dear Community
Is there any help from your side? Is there any possibility at least to change my email address  like I posted above in question 4.?
  • 9 months later...
Why even let us create an account with a non-professional email address then? It is not even clearly stated anywhere before signing up that a professional account is required to actually use the software.
  • Like! 2
