Tracking when Calypso user is changed.
Is there a way to know when a user has logged into or has changed in Calypso and or Autorun?
Like a log file.
Particularly when the user is changed.
We have two CMM's that are strictly Autorun, they log in the user as "Operator" with minimal rights.
I keep finding that someone is switching to Master.
Hi Richard,
there is no actual info within the CALYPSO log about a user change, i just tried it, but every time i switch the user i get the following:
"debug    Unknown    Unknown    0000    Update language settings."
I cant say if that message appears on any other occasion than switching users, so please use that info with caution 😄
You can find it under the following path: C:\Users\Public\Documents\Zeiss\CALYPSO 7.8\log
Best Regards
Marcel
 Can you change the Master password? Maybe use PCM variable getRecordHead("produceoper") and log that to a file after each run to see what time it is being changed to narrow it down?
Hello Richard,
I don´t think, that there is a way using log. But you can use PCM, like DWC said above. You can set an inspection_start_pcm.txt into your main folder, that writes the actual user into a file (with addToFile() ), with a  loop to read out, if the actual user changed to the former user (that is one row above), and if so, write it into a log-like file with time-stamp, name of former user and name of actual user.
Of course the log-like file can be identical with the first file, it only makes it a bit harder to read out, when there are time-stamps.
So there is one file
c:\Users\Public\Documents\Zeiss\CALYPSO 6.6\config\env\values
Search that periodically for "#lastUser
Under Tools-Settings-Work Environment you have the option to specify who is automatically logged in when the program starts.
Yes, we do that now. Auto logged in as Operator.
