[AG...] Posted March 25, 2025 Share Posted March 25, 2025 Just asking for some guidance here with this? Thank you. Link to comment Share on other sites More sharing options...
[Mi...] Posted March 28, 2025 Share Posted March 28, 2025 Hello, I would recommend checking out the tech guide article relating to the position check, there is a section on Composite Position as well. https://techguide.zeiss.com/en/zeiss-inspect-2025/article/cmd_inspection_check_position.html Link to comment Share on other sites More sharing options...
[Ti...] Posted March 28, 2025 Share Posted March 28, 2025 @AGH1977 Are you able to create the two features as a pattern? And is that how you are checking the top callout? If so, you can make the top and bottom callouts seperate checks bc regardless of whether you do this as composite or separate they are the same. This is bc the bottom callout with datum A only further refines perpendicularity and location ofbthe holes from each other. Link to comment Share on other sites More sharing options...
