Updating Curve Nominal
Would someone help me understand what I'm doing wrong here? I can execute the Curve, and it imports the correct nominals and measures it, but when I try to open the Line Profile to evaluate it, I get an error message saying "Unable to read nominal point file!".
After I get this error, it looks like it is setting the variable back to blank.
After further testing I found out that removing the inquireList and just hard coding the specific set alleviated the issue, but I don't understand why it is behaving that way at all.
The inquireList is just temporary for testing as I'll be moving to selectCase based specific measurements, but I'm just worried about this behavior. I'm hoping I don't have this same issue with selectCase.
Has anyone ran into this before, or could shed some light on if I'm doing something incorrect.
Try it, after you have replaced "Nominal Curves" by "NominalCurves".
The "space" into a path isn't 100% solved.
I prefer label without "space", it's easier to select by "DoubleClick".
I'll try that, but as you can see in the last picture, it still resolved the Nominal Curves portion, it is just wiping the setNo variable for whatever reason. It only wipes it when you open the characteristic - you can open/close the feature as much as you'd like and there are no issues. Maybe it's a bug, maybe I'm an idiot. Lol.
Where did you place the pcm code? In the "global" presettings or the presettings of the characteristic or feature?
For this it will have to be in the pre-setting of the feature.
The value of the parameter setNo gets deleted if you open the characteristic because it invokes the curve and its pre-settings. The inquireList command is not executed.
Try something like :
if getCNCMode()=="cnc"
setNo=inquireList("blabla", "Kurve","Kurve2")
endif
curevloc="C:\Temp\" + setNo+ ".txt"
Cube_LoadCurve.zipFetching info...
I assign critical parameter always inside the pre-settings of inspection, so I'm sure to have correct parameter.
Sometimes, I doesn't know why, a default value must be assigned inside the inspection parameter, or parameter file.
The attached inspection would be run with simulation CALYPSO 7.8.
