Getting coordinates from boundary selection
When recording the following command...
gom.script.selection3d.select_boundary (
	coordinate=gom.Vec3d (-4.55772701e+00, -2.39591760e+01, 4.51351517e+02),
	only_select_edges=True,
	restrict_to_segment=False)
I see it has the coordinate parameter. I'd like to be able to select multiple boundaries and store the gom.Vec3d coordinates to be able to loop through and re-apply later. However the select_boundary command returns only None. Is there a way to extract that information?
From any element you can get the coordinates as a NumPy array by:
F2 in script editor (or RMB in script editor -> Insert -> Element Value)
which will provide a python line as:
np.array (gom.app.project.parts['Part'].actual.data.coordinate)
When you only want to get the selected points after your selection command, you can edit this line to:
np.array (gom.app.project.parts['Part'].actual.selection.coordinate)
to get all selected points from the actual mesh as NumPy array.
I hope this helps and fits your needs.
  • 2 months later...
if you only want repeat selection on same element,you can :
1,creat a element(exp. a fitting point named'p1')using this selection.
2, restore selection:
gom.script.sys.restore_point_selection (elements=[gom.app.project.actual_elements['p1']])
