[Sh...] Posted May 25, 2021 Share Posted May 25, 2021 When recording the following command... gom.script.selection3d.select_boundary ( coordinate=gom.Vec3d (-4.55772701e+00, -2.39591760e+01, 4.51351517e+02), only_select_edges=True, restrict_to_segment=False) I see it has the coordinate parameter. I'd like to be able to select multiple boundaries and store the gom.Vec3d coordinates to be able to loop through and re-apply later. However the select_boundary command returns only None. Is there a way to extract that information? Link to comment https://qualityforum.zeiss.com/topic/229-getting-coordinates-from-boundary-selection/ Share on other sites More sharing options...
[Th...] Posted May 27, 2021 Share Posted May 27, 2021 From any element you can get the coordinates as a NumPy array by: F2 in script editor (or RMB in script editor -> Insert -> Element Value) which will provide a python line as: np.array (gom.app.project.parts['Part'].actual.data.coordinate) When you only want to get the selected points after your selection command, you can edit this line to: np.array (gom.app.project.parts['Part'].actual.selection.coordinate) to get all selected points from the actual mesh as NumPy array. I hope this helps and fits your needs. Link to comment https://qualityforum.zeiss.com/topic/229-getting-coordinates-from-boundary-selection/#findComment-656 Share on other sites More sharing options...
[We...] Posted August 6, 2021 Share Posted August 6, 2021 Please sign in to view this quote. if you only want repeat selection on same element,you can : 1,creat a element(exp. a fitting point named'p1')using this selection. 2, restore selection: gom.script.sys.restore_point_selection (elements=[gom.app.project.actual_elements['p1']]) Link to comment https://qualityforum.zeiss.com/topic/229-getting-coordinates-from-boundary-selection/#findComment-993 Share on other sites More sharing options...
