[Ru...] Posted April 1, 2025 Share Posted April 1, 2025  Hello  I’m using Gom inspect version 2025, but the created inspection files cannot be opened by my colleagues in other plant that are using old version 2023 ,  Is possible for version 2025 save the file to be compatible with older versions?  Link to comment https://qualityforum.zeiss.com/topic/22937-fileginspect-made-on-gom-inspect-2025-to-be-opened-in-version-2023/ Share on other sites More sharing options...
[Na...] Posted April 1, 2025 Share Posted April 1, 2025 Hello Ruben, the projects are not backwards compatible from version to version. If your colleagues want to open the projects they might want to get the free license for 2025. Nanno Link to comment https://qualityforum.zeiss.com/topic/22937-fileginspect-made-on-gom-inspect-2025-to-be-opened-in-version-2023/#findComment-129365 Share on other sites More sharing options...
[Ru...] Posted April 1, 2025 Author Share Posted April 1, 2025 Ok thanks  But if the upgrade to to version 2025 , then they cannot open the already performed programs in version2023 , right ?  Link to comment https://qualityforum.zeiss.com/topic/22937-fileginspect-made-on-gom-inspect-2025-to-be-opened-in-version-2023/#findComment-129367 Share on other sites More sharing options...
[Na...] Posted April 1, 2025 Share Posted April 1, 2025 You can open "old" projects in "new" software versions, but not a "new" project in "old" software 🙂 Link to comment https://qualityforum.zeiss.com/topic/22937-fileginspect-made-on-gom-inspect-2025-to-be-opened-in-version-2023/#findComment-129377 Share on other sites More sharing options...
