PCM message, not skipping cncBreak
Run=inquire("Is the Block Fixture moved out of the way?"+cr()+"You can move the fixture now."+cr()+"User must answer YES to continue."+cr()+"CMM will stop if wrong answer.")
if Run=="YES"
else
cncBreak()
endif
Two things, I would like the answer to not be case sensitive and why is cncBreak activated when the user types "YES"?
Any help is appreciated.
I think this would work - i have no pcm, but result element is not complaining
Run=inquireText(...).toLower()
Edit: should use inquireText
Edited
