Distance between cone and sphere
Hi All,
who can help ?
I would like to measure a size of 0.4 with the measuring machine Zeiss acura with the latest Calypso software.
It is a cone of 90° and there is a sphere of 0.4mm through it. would like to measure perpendicular to the cone.
How could I program this20250401085620430.pdf
If you simplyfi it into cut - so only circle and 2d line, then you can use intesection to obtain two points. Use them as 3d line. Next you can use caliper distance with rotated alignment to obtain that value.
