[Ri...] Posted April 2, 2025 Share Posted April 2, 2025 I have one CMM where it continually fails to load a named file to start Autorun. It's hard coded in the Calypso environment, yet Autorun when started looks for another name (same location). Is there a menu in Autorun that defines the name when loading? Link to comment https://qualityforum.zeiss.com/topic/22959-autorun-fails-to-load-pallet-file/ Share on other sites More sharing options...
[To...] Posted April 2, 2025 Share Posted April 2, 2025 Please sign in to view this quote. Are you using different user names? Link to comment https://qualityforum.zeiss.com/topic/22959-autorun-fails-to-load-pallet-file/#findComment-129483 Share on other sites More sharing options...
[Ri...] Posted April 2, 2025 Author Share Posted April 2, 2025 (edited) They are both logged in as "Operator", which is forced when starting Calypso. Butt... I will have to see if the error message comes up when I log in to fix programs (Exit autorun, start Calypso. etc). Edited April 2, 2025 Link to comment https://qualityforum.zeiss.com/topic/22959-autorun-fails-to-load-pallet-file/#findComment-129485 Share on other sites More sharing options...
[Ma...] Posted April 2, 2025 Share Posted April 2, 2025 First login as Master or someone who has rights to edit settings and don't open in autorun. Open settings where you can edit what happens after login. Change to user who needs change. Go to settings and select correct autorun file. I think this should be also editable somewhere in file. There are mentions about autorun file a few times. c:\ProgramData\ZEISS\Calypso x.x\users\USER_NAME\config\env\values Link to comment https://qualityforum.zeiss.com/topic/22959-autorun-fails-to-load-pallet-file/#findComment-129497 Share on other sites More sharing options...
[Ri...] Posted April 4, 2025 Author Share Posted April 4, 2025 Thanks for the help, I think I found the errant login. Link to comment https://qualityforum.zeiss.com/topic/22959-autorun-fails-to-load-pallet-file/#findComment-129681 Share on other sites More sharing options...
