Get the scan diameter from a plane?
I thought I had asked this once before, but I am not finding anything.
I have a plane; it has a value for the circle scan.
Can I extract that value?
I have tied hands, but would help this? I only got list, but i can not continue with selection - no pcm lic
getNominal("Rovina1").measElement.technology.list
Try this (for inch units ; for metric remove /25.4) :
PlanePathCenter=(getActual("Plane1").measElement.technology.actSegmentObject.diameter)/25.4
I just started using it yesterday. Before I would have used if statements haha.
I'm not a huge fan of it as it's just increasing the complexity of the code, but it is nice to use if needed.
I generate an error. PCM doesn't like "Access Attribute = diameter".
Object "#68.3,1c2 Ø.6299 Min" is a Result element.
Edited
Since you can place formula into that diameter - would be better to use this approach? Or why you need to get this "hardcoded" number?
Edit:
BTW i just tested that formula - if you place getNominal instead of getActual - then it works ( version 6.6 ) - maybe newer version of Calypso will not work.
Edited
I was thinking the same -  I would just set this as a VARiable using a formula inside the field.
Unless for some reason you need to output the value for 'proof' on report...
I tested on 2023 and it output proper value.
I might give this a try : in the post characteristics (and plan advanced parameters) - declare a variable :  PlaneDia(getActual("Plane1").measElement.technology.actSegmentObject.diameter)/25.4
The in Result element choose 'number' instead of Length.
If that doesn't work : you may be able to put this variable in the comment field (with formula) of the any feature related to this plane/scan.
Good luck !🤔
