What is the function "Convert to Stagewise Editable element" for ?
Hi,
this is a command to convert an element to a standard actual element, which can be edited stagewise without discarding the results from other stages and can be applied to UDE. If you have for example a UDE (user defined evaluation)/skript, where the results in a stage project may need different starting values from stage do stage to get the correct result you can use this function to make UDE stagewise independent. A usecase is for example to define a correct image for a crack tip evaluation when occuring different starting points due to rough surfaces.
