[Ha...] Posted May 26, 2021 Share Posted May 26, 2021 Hi, - The first problem: The Atos core 300 often has to be recalibrated after a day or two of use, even though the room temperature doesn't change much. - The second problem:it is not getting the reference point when not calibrated, I tried to test the connection on the line, check the connection on the software but still can't fix it, hope you have a solution to reduce the effective time correction. Thanks & Best regards. Link to comment Share on other sites More sharing options...
