[Ke...] Posted April 4, 2025 Share Posted April 4, 2025 I know that I have seen (but cannot find) how to remove the MMC result for a Position characteristic... which I thought might help. I have a Position that requires a Best Fit, to report in the X direction only, so I need to report ONLY in the X direction. Since I do not see a way to turn off the reporting in the Z direction, I need to remove the overall result, and the Z direction, leaving only the Position in X results (unless there is another way that I am unaware of) Link to comment Share on other sites More sharing options...
[An...] Posted April 4, 2025 Share Posted April 4, 2025 Hi Keith, I could swear that there used to be a good Knowledge Base article on this. I'm not sure if it's what you're looking for based on what you described, but I think this thread may have the info you want. It's old, but I have used the method that Richard describes as recently as six or so months ago. Link to comment Share on other sites More sharing options...
[Ke...] Posted April 4, 2025 Author Share Posted April 4, 2025 Please sign in to view this quote. This looks like exactly what I was looking for. Thanks! Link to comment Share on other sites More sharing options...
[Ky...] Posted April 4, 2025 Share Posted April 4, 2025 Took me a while, but I found the knowledge base article, in case that helps. https://portal.zeiss.com/knowledge-base?id=458620 Link to comment Share on other sites More sharing options...
[Ke...] Posted April 5, 2025 Author Share Posted April 5, 2025 (edited) Please sign in to view this quote. Thanks! Edited April 5, 2025 Link to comment Share on other sites More sharing options...
