[Ke...] Posted Friday at 01:48 PM Share Posted Friday at 01:48 PM I know that I have seen (but cannot find) how to remove the MMC result for a Position characteristic... which I thought might help. I have a Position that requires a Best Fit, to report in the X direction only, so I need to report ONLY in the X direction. Since I do not see a way to turn off the reporting in the Z direction, I need to remove the overall result, and the Z direction, leaving only the Position in X results (unless there is another way that I am unaware of) Link to comment Share on other sites More sharing options...
[An...] Posted Friday at 02:27 PM Share Posted Friday at 02:27 PM Hi Keith, I could swear that there used to be a good Knowledge Base article on this. I'm not sure if it's what you're looking for based on what you described, but I think this thread may have the info you want. It's old, but I have used the method that Richard describes as recently as six or so months ago. Link to comment Share on other sites More sharing options...
[Ke...] Posted Friday at 02:40 PM Author Share Posted Friday at 02:40 PM Please sign in to view this quote. This looks like exactly what I was looking for. Thanks! Link to comment Share on other sites More sharing options...
[Ky...] Posted Friday at 09:05 PM Share Posted Friday at 09:05 PM Took me a while, but I found the knowledge base article, in case that helps. https://portal.zeiss.com/knowledge-base?id=458620 Link to comment Share on other sites More sharing options...
[Ke...] Posted yesterday at 03:13 PM Author Share Posted yesterday at 03:13 PM (edited) Please sign in to view this quote. Thanks! Edited yesterday at 03:17 PM Link to comment Share on other sites More sharing options...
