Need Help For mesuring Curve Feature in Calypso 5.2
Hello Everyone,
I'm using Calypso 5.2, in this version whenever i tried to measur a curve, always pop up a error "Curve feature is not Available".
please help me about this issue solving.
Norbert is correct. That message indicates that you do not have the proper license for create a curve feature. More to the point, if you really are running 5.2 (and it isn't a typo), there is no way to get a license for that version. Current licenses do not work with versions that old and the old license server no longer exists. I'm afraid you'll either have to upgrade the version or use a work around. I'm assuming from the time you posted this, you aren't in North America. If you were, I would give a link to a document in our knowledge base. Long story short, it would be a bunch of space points and calculating their space point differences.
Just in case, the link is here:
https://portal.zeiss.com/knowledge-base?id=2495545
