Export all the pcm in measurement plan
Dear All,
Do you have a method to export all the PCM command in a plan? such as every element or charactersitic use formula liked getActual.....   and so on.
Include result element
Thank you !
Not currently something that is easily achievable within CALYPSO.  There are other ways (think NotePad++ and regEx).
Additionally, this may be part of a larger feature coming in 2026
  • Like! 1
Copy the "pcmFormula.cfpcm" and "pcmPara.cfpcm" files inside your inspection folder and run the following code.
Afterwards see the filese "pcm-Code1.txt" and "pcm-Code2.txt" in your inspection folder.
space= "          "
pcmFilesList=list("pcmFormula.cfpcm","pcmPara.cfpcm")
for k=1 to pcmFilesList.size
fileOut=directoryPath("actualInspection")  +  "\pcm-Code" + k + ".txt"
   if (fileExists(fileOut)==true)  then
      deleteFile(fileOut)
          endif
pcmFile=directoryPath("actualInspection")  + "\" + getParameterNamed(pcmFilesList,k)
runPCMFile(pcmFile)
// don't rename dataAll! It's defined inside the .cfpcm files
dataAll.first.size
for i=1 to dataAll.size
data=getParameterNamed(dataAll,i)
output=""
for j=1 to dataAll.first.size
selectCase j
case 2 to (dataAll.first.size-1)
    if  getParameterNamed(data,j)<>""
	output = output + space + getParameterNamed(data,j)  + space
     else
      output = output + space + "-"  + space
	 endif
caseElse
	output = output + getParameterNamed(data,j)
     else
      output = output +  "-"
	 endif
endSelect
next j
addToFile(fileOut,output + cr())
next i
next k
pcmFormula.cfpcm pcmPara.cfpcm
Edited
  • Like! 1
deleteFile("c:\TMP\file.cfpcm")
addToFile("c:\TMP\file.cfpcm","TSfA36+5oAvxbw3Lgyhvs1vqHNKBRe6S1SsXeHeqYQhkMW31HP8bPVDK1fU0Wyudyg0VtMBny4VIP1mTqAu4JbrMT4A1S2PFkbJ+MRsaJD4=")
runPCMFile("c:\TMP\file.cfpcm")
  • Like! 1
  • 4 weeks later...
what kind of cracy files these are in the attachment? i tryed to read them
Me too and almost broke my eyes.
It's has something to do with Base64 encoding.
