[ca...] Posted April 8 Share Posted April 8 Hello everyone, I'm trying to follow the instructions presented in 2025/howtos/starting_options/starting_options.html. I encountered an error when sending arguments from an exe file to the python script inside ZEISS software. params = {'portno': main.port, 'insp_id': insp_id, 'partno': partno, 'serlno': srlno} result = subprocess.run(["C:/Program Files/Zeiss/INSPECT/2025/bin/ZEISS_INSPECT.exe", "-eval", "gom.script.userscript.service_coordinator(parameters=" + str(params) + ")"], text=True, capture_output=True, check=True) In service coordinator.py, I got an error which says insp_id is not defined. Could you please help me to solve the issue? if 'insp_id' not in globals() or 'portno' not in globals() or 'serlno' not in globals(): insp_id = 'default_value_1' portno = 'default_value_2' serlno='default_value_3' if hasattr(gom, 'read_parameters'): gom.read_parameters(globals()) insp_id=insp_id serlno=serlno portno=portno variable_list=[portno,insp_id,serlno] print(variable_list) Link to comment Share on other sites More sharing options...
[Ma...] Posted April 8 Share Posted April 8 Hi cansetm, I tried to reproduce your approach as follows. I created the following Python script which is executed from the command line: import subprocess params = {'portno': 1, 'insp_id': 'insp123', 'partno': 'part1', 'serlno': '1234'} result = subprocess.run(["C:/Program Files/Zeiss/INSPECT/2025/bin/ZEISS_INSPECT.exe", "-eval", "gom.script.userscript.service_coordinator(parameters=" + str(params) + ")"], text=True, capture_output=True, check=True) As compared to your script, I just replaced the values in the 'params' dictionary. I created an App with the following implementation of 'service_coordinator.py': if 'insp_id' not in globals() or 'portno' not in globals() or 'serlno' not in globals(): insp_id = 'default_value_1' portno = 'default_value_2' serlno = 'default_value_3' if hasattr(gom, 'read_parameters'): gom.read_parameters(globals()) variable_list=[portno,insp_id,serlno] print(f"{variable_list}") with open("C:/Temp/app.log", 'w') as f: f.write(f"{variable_list}") As compared to your script, I removed the variable assignments at the end and added writing of the variables to the file "app.log". When I check the contents of "app.log", I see [1, 'insp123', '1234'] Hope this helps! Best regards, Matthias Link to comment Share on other sites More sharing options...
[ca...] Posted April 8 Author Share Posted April 8 Hello Matthias, I tried with your method. It worked only first time when I run the code, and variables have the default values in all other attempts. What could be the reason of the problem? Is there any other robust way of sending arguments? Many Thanks, Canset Link to comment Share on other sites More sharing options...
[Ma...] Posted April 9 Share Posted April 9 Hi Canset, What exactly do you mean by "It worked only first time when I run the code"? Does this mean you leave ZEISS INSPECT open and run the Python script from the command line a second time? Best regards, Matthias Link to comment Share on other sites More sharing options...
[ca...] Posted April 9 Author Share Posted April 9 (edited) Hello Matthias, It only worked one time and after that I closed the ZEISS Inspect and command prompt, and tried to reproduce the case from the command line. Log files were remained empty for the all other attempts. You can also find the service log which shows that values of the variables could not be assigned. Many thanks, Canset Edited April 9 Link to comment Share on other sites More sharing options...
[Ma...] Posted April 9 Share Posted April 9 Hello Canset, When reading your previous posts, I did not realize that you were actually sending the arguments to a script working as a service! I will have to check if this actually works. The mechanism I described is intended for "normal" scripts. Best regards, Matthias Link to comment Share on other sites More sharing options...
[ca...] Posted April 9 Author Share Posted April 9 Hello Matthias, Actually, I am sending arguments to a script which has a call for service function inside but this script is not the service.py itself. Many thanks for your effort 🙂 Canset Link to comment Share on other sites More sharing options...
[Ma...] Posted April 10 Share Posted April 10 Hello Canset, Thanks for the clarification. Now I have no idea what might go wrong on your side. Yesterday I tried the setup I posted on Tuesday multiple times and did not encounter any issues. Best regards, Matthias Link to comment Share on other sites More sharing options...
[Ma...] Posted April 10 Share Posted April 10 Maybe the following example might help you to achieve your goal: zeiss-inspect-app-examples/AppExamples/misc/IPCWebsocketBasics/doc/Documentation.md at main · ZEISS/zeiss-inspect-app-examples Link to comment Share on other sites More sharing options...
[ca...] Posted April 17 Author Share Posted April 17 Hello Matthias, Thanks for your help. I solved the problem with asyncio. I have one more question. Is it possible to use services for let's say for importing mesh data,report editing purposes? Because when I use the service for this kind of task, service is running without encountering any problem but ZEISS could not continue to task when user is logged out. It makes me think that these services are different compared to windows service format. Any idea why this happens? Thanks, Canset Link to comment Share on other sites More sharing options...
[Ma...] Posted April 23 Share Posted April 23 Hello Canset, the ZEISS INSPECT services are completely different from Windows services. They are run within ZEISS INSPECT. Best regards, Matthias Link to comment Share on other sites More sharing options...
