Slot - Perpendicularity Evaluation
I have a slot perpendicularity callout of 0.100mm, that is applied to the width in a multiple single segment control frame.
The material is 8mm thick, so the walls of the slot are 2.5mm x 8mm.
As an example:
When I recall the points into a Symmetry Plane, the form of the Symmetry Plane is 0.111mm (the form of each wall of the slot is 0.040 & 0.060mm). The Perpendicularity of this example is 0.1470, to the Datum. However, if I scan the entire feature as a 360 degree slot at multiple levels and recall those derived centerpoints into a 3d line, the perpendicularity of that 3d line is well within 0.020.
I feel that, since the perpendicularity callout is tied directly to the Slot Width, then the Symmetry Plane evaluation is the correct one...
Agree or Disagree?
Thanks!
Considering the position of the feature control frame (and the double arrowed line) I would actually interpret that more as a position and perpendicularity of the symmetry plane between the two sides rather than the slot itself.
I agree with Kyle.
The perpendicularity call out is a refinement of the positional call out. Which means the 3D line method you mentioned would more accurately report what the print is calling out.
I agree with the above as well, however is anyone is pressing you for more ... I have measured the side radii and cylinders and you can get the perpendicularity of all the 2 radii and 2 planes and report all 4 or simply report the maximum of all 4 as the 'slot' perp value.
