[Le...] Posted April 14 Share Posted April 14 When using Outer Disk Caliper, is there a way to retrieve the point where the caliper intersects with the part? I am interested in the mesh point with the max distance, according a defined axis. (All point coordinates) The outer disk caliper allows me to place it exactly a the border point that I want to determine, but how can I retrieve the intersection point of Caliper Disk and Part? Help is highly appreciated, Leon Link to comment Share on other sites More sharing options...
[Na...] Posted April 14 Share Posted April 14 Hi Leon, you could construct two separate touch points (disc) and then a two point distance between the two points. Nanno Link to comment Share on other sites More sharing options...
