Simultaneous Profile Requirement
I just recently upgraded to Calypso 2024 from 2019, I am trying to figure out how to setup two surface profiles using simultaneous requirement. I browsed through some of the other forum topics but I can't figure out how to get it setup correctly.
I am not sure if this is correct, but you can use freeform - recall all measured points into this one and in evaluation of freeform make alignment.
Or this freeform can be used as one feature for profile callout.
I don't get sim callouts, so i am not used to it and i didn't get head around that.
whenever there are multiple DRF's with the same structure, that is not fully constrained, or has MMB/LMB, they must all be evaluated simultaneously.  In other words, one position can't datum shift in one direction and another position shift in another direction.
I figured out what I was doing wrong. When I was creating the two different profiles, I didn't have the datums set up identically. My Datum A for Profile 1 and Profile 2 were being evaluated differently so it wouldn't show the SimReq tab.
