[Ad...] Posted April 24, 2025 Share Posted April 24, 2025 Is there a way to set User Defined Variable selections and the desired PiWeb Generic report that I want to use globally? I want to use the same user variables and report for every program. Currently the only sucessful method I've found is opening multiple printouts ...then user defined variables to select the ProtolocHeader.xml file that's located in the Users/Public/Documents/Zeiss/Calypso/Data folder then selecting the desired "Generic Templates" and saving each individual program. This is a time drain when you have several hundred programs that would require an individual touch like that. Where is the petition to print the custom printout back? ha Link to comment Share on other sites More sharing options...
[DW...] Posted April 24, 2025 Share Posted April 24, 2025 Please sign in to view this quote. Please sign in to view this username. If someone chimes in on where this information is stored for each inspection program, I can work on a script that automates the replacement process. Link to comment Share on other sites More sharing options...
