Freiformfläche Messdaten exportieren
I think you can do this, but i believe you either enable or disable for all features for automatic. You can right click on needed feature and click on write points.
Prerequisites -> Results to File -> Export files - click Configuration and set to Nom/Act Comparison - check needed informations to be stored and don't forget to set path for that file.
I hope you'll find something usefull for that.
  • Thank you! 1
