[Ch...] Posted April 30, 2025 Share Posted April 30, 2025 How do I create a curve from theoretical points? I feel like this should be possible, but I can't figure out how. I have been doing too much management stuff and even have my own cmm programmer now; please tell me that I'm not losing my touch. 1 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/ Share on other sites More sharing options...
[Cl...] Posted April 30, 2025 Share Posted April 30, 2025 Just a thought. What if you open the curve strategy, click on segment - List. Here you can save the points. I'm wondering if you can open the point list in Notepad and add the points? Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131229 Share on other sites More sharing options...
[Ma...] Posted April 30, 2025 Share Posted April 30, 2025 There are so many ways to alter curves. I am lost at what you want to achieve - as Clarke stated - you can save points from curve, alter it in text editor and then load nominals into new curve. You can rotate nominals, move them. You can even mirror curve - with and without help of model. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131231 Share on other sites More sharing options...
[Cl...] Posted April 30, 2025 Share Posted April 30, 2025 (edited) Trying it in simulation now. Edited April 30, 2025 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131233 Share on other sites More sharing options...
[Cl...] Posted April 30, 2025 Share Posted April 30, 2025 With existing curve. Click on the down arrow on the left. Scroll down to the last point. Right click, copy point. Paste point. A dialog box will open with the XYZ, IJK values to edit. I just tried it and it worked. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131237 Share on other sites More sharing options...
[Ch...] Posted April 30, 2025 Author Share Posted April 30, 2025 I don't think I'm being clear about the goal. There is no existing curve. The points are not in a straight line and can't be created with curve. It's hard to tell in the picture, but the theoretical points are all in the same plane, while the original points are not. I could make it using FreeForm, but I can't report radius's as they change along the compressor wheel profile. They are individual points taken along the edge of a compressor wheel. Then I create theoretical points and use formulas to put all the points in the same plane. In a perfect world I could recall those theoretical points into a curve. But it won't let me. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131245 Share on other sites More sharing options...
[Ma...] Posted April 30, 2025 Share Posted April 30, 2025 Until monday i can not try that, but you should be able to recall points into curve. Just don't use theoretical - use normal points with strategy, where formulas will be in nominals. This should let you recalculate curve. Otherwise you would need SW for models and make that curve from model. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131247 Share on other sites More sharing options...
[Cl...] Posted April 30, 2025 Share Posted April 30, 2025 (edited) Assuming you have the XYZ/IJK of each point? They can be entered individually into a curve feature. Or am I still not getting it? Edited April 30, 2025 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131251 Share on other sites More sharing options...
[To...] Posted April 30, 2025 Share Posted April 30, 2025 Is this close to what you're looking for? Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131253 Share on other sites More sharing options...
[Ow...] Posted April 30, 2025 Share Posted April 30, 2025 (edited) It's been awhile since I've done it but, basically type your nominals into different columns of an excel document and then save the document as a (Tab Deliminated).txt file and then read that file into curve like Tom defined above. In the 2D curve example illustration I've attached, first row is X, 2nd Y, 3rd row Z. If it is a 3D curve, you'll need the Unom, Vnom,wnom's vectors as well.(I,J,K). Edited April 30, 2025 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131255 Share on other sites More sharing options...
[Ow...] Posted April 30, 2025 Share Posted April 30, 2025 I tried to edit my original post to include that you have to have nominals in a curve to recall points into it, it won't recall points to create nominals. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131263 Share on other sites More sharing options...
[Ma...] Posted May 1, 2025 Share Posted May 1, 2025 Please sign in to view this quote. You can recalculate so nominals can be created. But i think it won't work on theoretical points - it has to be normal points. Recalculating without actuals will make nominal curve from nominals - with actuals will create nominal curve from actuals. It works the same as recalling measured points from standard features. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-131287 Share on other sites More sharing options...
[Iv...] Posted December 16, 2025 Share Posted December 16, 2025 Please sign in to view this username. Did you ever find a solution for recalling theoretical points into a curve? As you said, it seems doable, but the software is not allowing it. Thanks Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143767 Share on other sites More sharing options...
[Iv...] Posted December 16, 2025 Share Posted December 16, 2025 I can't validate it at the moment, but hopefully I can test it out by the EOD. I want to try recalling the non-theoretical points into a curve. Once recalled, delete those points and rename the theoretical points with the same name as the deleted points. I tested one point out, and it looks like the theoretical point still connects to the curve! I don't know if it will blow up as soon as you run the results 🤔 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143769 Share on other sites More sharing options...
[Iv...] Posted December 17, 2025 Share Posted December 17, 2025 Please sign in to view this username. So, I tested it out, and it works... sort of. The curve adopts the theoretical points after you delete the actual points, with the same name caveat, of course. But the actuals(XYZ) within the curve do not match the theoretical actual (XYZ). They are close in some cases, but then like 2mm plus off in others. So not sure where those numbers are being pulled from. My theoretical points are Symmetry Points, so maybe that is having an influence? Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143785 Share on other sites More sharing options...
[Ma...] Posted December 17, 2025 Share Posted December 17, 2025 I use CAD/ Creating Features/ Freeform/ Curve and select the file option to import the points. That is if you have Freeform/ Curve as an option. 1 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143787 Share on other sites More sharing options...
[Ri...] Posted December 17, 2025 Share Posted December 17, 2025 Can't you convert the theocraticals to physicals then create a Curve? I have created theoretical points based on alignments to ensure vectors are correct, then make them a physical point. 1 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143793 Share on other sites More sharing options...
[Iv...] Posted December 17, 2025 Share Posted December 17, 2025 Please sign in to view this username. Yes, but that would only create the nominal curve, correct? In this case, I already have the nominal curve, but I'm unable to get the actuals into the curve since they are theoretical, and CALYPSO will not allow it. Below is the concept that I'm producing. Creating the theoretical symmetry points based on the max/min coordinate points of multiple opposing curves. I'm then able to bring these into a curve feature using the delte method that I mentioned above (somewhat). Because I already have the nominal points from the symmetry points, and there are only 14 points, I created it by hand. If there were more points, I would've used the method you mentioned to create the nominal path. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143803 Share on other sites More sharing options...
[Iv...] Posted December 17, 2025 Share Posted December 17, 2025 Please sign in to view this username. I'm not sure if I'm following correctly? Yes, you can change theoretical points to actual points if there is a physical feature to contact. In my case (and Chad Watton's), there is no physical feature to contact. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143805 Share on other sites More sharing options...
[Ma...] Posted December 17, 2025 Share Posted December 17, 2025 Please sign in to view this quote. I was addressing Chad's question. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143811 Share on other sites More sharing options...
[Ri...] Posted December 17, 2025 Share Posted December 17, 2025 Please sign in to view this quote. Why do you need to have a physical feature to create physical points from theoretical points? If the theoretical points are where you believe they should be and you convert to physical points, run the points and see what values you get. Then try to use them in Curve. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143817 Share on other sites More sharing options...
[Ma...] Posted December 18, 2025 Share Posted December 18, 2025 You can use Min and Max coordinate feature to obtain such thing from curve - then this is linked to nominal and actual, so this "3d point" can be used as actuals. It's in construction close to min/max element Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143841 Share on other sites More sharing options...
[Iv...] Posted December 19, 2025 Share Posted December 19, 2025 Please sign in to view this username. I don't think we are on the same page. I already have these points created in my program; they hold values. But for whatever reason, Curve does not allow me to recall these points. Please sign in to view this username. I actually have several min and max coordinate features already in the measurement plan. But again, CALYPSO does not allow you to recall these coordinate points. I tried toggling the min/max coordinates from point to 3d point, but it didn't help. 1 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143907 Share on other sites More sharing options...
[Ma...] Posted December 19, 2025 Share Posted December 19, 2025 (edited) Please sign in to view this quote. I don't think this feature is able to give measured points in this way. But i think you can use single point - use only recall and select that maximum coordinate feature. I am not sure if this can be recalled as recall measured points, but point is in recall option. But thanks for trying another options and telling us. Unfortunatelly we are having Christmas holiday, so i am out of Calypso until January. Edited December 19, 2025 1 Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143909 Share on other sites More sharing options...
[Iv...] Posted December 19, 2025 Share Posted December 19, 2025 Please sign in to view this username. Cheers to staying on the forum when on holiday! 🍻 You are correct. The theoretical points (such as symmetry, max/min coordinate) are only available when using the recall option, not the recall feature points. I did try recalling my theoretical points into a single point. Before recalling my point in the space point, I was able to recall it in a curve. However, after recalling the point, I could no longer recall the point in the curve feature. Link to comment https://qualityforum.zeiss.com/topic/23297-create-a-curve-from-series-of-theoretical-points/#findComment-143919 Share on other sites More sharing options...
