[Ma...] Posted May 7 Share Posted May 7 (edited) Hi there, i am looking for a way to write into report inspection plan path. I have Calypso 2018 ( 6.6 ). No PCM Only way i found was using user fields, but there you can not use any formulas to get that automatically ( writing it manually will not solve possible changes in directory structure ) Reason: when i am ill / on vacation - colleagues are not used to be here and can not find inspection plan to see problematic place. Autorun is not helpfull too due to reducted plan path. Any ideas? Thanks Edited May 7 PCM info Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7 Share Posted May 7 Please sign in to view this quote. I would probably just poor man it with putting a formula inside the comment of the first Characteristic. getActualInspectionDir() 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted May 7 Author Share Posted May 7 Please sign in to view this username. Thanks for that function - i'll play with that later 🙂 Btw - can you set / alter user field or anything related to header with PCM after start? Basic calls can be used without PCM license. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7 Share Posted May 7 Please sign in to view this username. I guess it depends exactly what you are trying to doing, but absolutely you can change header parameters with PCM via the pre-settings or post-settings. You can try to do it via the comment section of a characteristic, or in the formula field of a ResultElement. setRecordHead("company", getActualInspectionDir()) This works. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7 Share Posted May 7 Please sign in to view this username. I just did testing where I created a new userfield for the Inspection Directory, and mapped it. Then in the formula of the Result Element I put this in the formula. It appears to work. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted May 7 Author Share Posted May 7 Please sign in to view this username. Thanks a lot!!! This seems to be final solution. I'll do some tests next week when i'll have spare time 🙂 Link to comment Share on other sites More sharing options...
[Ch...] Posted May 11 Share Posted May 11 Please sign in to view this username. Hi, I have a question. Do I need a license to use this mapping dialog box? I want to open it, but nothing appears. I don't know if I need to enable it somehow or contact Zeiss support. Link to comment Share on other sites More sharing options...
[Ma...] Posted May 13 Author Share Posted May 13 Please sign in to view this username. I have just noticed - once you use mapping, then you can not use "u_workdir" but you have to use that mapped K num. I've tried with result element - works. I'll try to hide it in condition or nominal formula - i am not sure for old protocols - perhaps tommorow i will have time. Please sign in to view this username. this should be without any license - just Calypso. What version of Calypso you have? Link to comment Share on other sites More sharing options...
[Ch...] Posted May 15 Share Posted May 15 Please sign in to view this username. version 2023,Apparently my employer had a block with a folder that activated that tool, it has been resolved, thank you very much for the help. 1 Link to comment Share on other sites More sharing options...
