[Do...] Posted May 7, 2025 Share Posted May 7, 2025 So, I have a situation where a customer has a part that calls out a true position using A & B together. FCF reads pos.|ØX.XX|A-B|C|. How do I program a characteristic that uses both datum planes as a single datum? Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7, 2025 Share Posted May 7, 2025 If you have the new GD&T engine, you can do Common Datums. Otherwise, in this case, I'd probably just use a Symmetry Plane (not Symmetry). Link to comment Share on other sites More sharing options...
[Do...] Posted May 7, 2025 Author Share Posted May 7, 2025 Please sign in to view this quote. I do not have teh new GD&T engine, unfortunately. I will use the Symmetry Plane option. Thanks for your help clarifying it. Link to comment Share on other sites More sharing options...
[Ma...] Posted May 7, 2025 Share Posted May 7, 2025 Please sign in to view this username. wouldn't be there any problems within symmetry plane when uneven number of points and location? I always used that sym plane with same opposing points. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7, 2025 Share Posted May 7, 2025 Please sign in to view this quote. Please sign in to view this username. I was unaware of those issues, but if that is a known issue, then I wouldn't recommend it then. Lol. You could either then use Symmetry from each individual plane, or you could leverage Free-Form. Link to comment Share on other sites More sharing options...
[Ma...] Posted May 7, 2025 Share Posted May 7, 2025 Please sign in to view this username. I am not sure if there are any problems, so i asked. I think i need some testing - i hope i'll find some time for that 🙂 Link to comment Share on other sites More sharing options...
[Je...] Posted May 8, 2025 Share Posted May 8, 2025 Please sign in to view this quote. You are right, when talking about the two-point-distance. LSQ and (in this case) Maximum Inscribed Element should work. 1 Link to comment Share on other sites More sharing options...
[Je...] Posted May 8, 2025 Share Posted May 8, 2025 Please sign in to view this quote. Minimum Circumscribed I mean of course, sry Link to comment Share on other sites More sharing options...
