[Do...] Posted May 7, 2025 Share Posted May 7, 2025 So, I have a situation where a customer has a part that calls out a true position using A & B together. FCF reads pos.|ØX.XX|A-B|C|. How do I program a characteristic that uses both datum planes as a single datum? Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7, 2025 Share Posted May 7, 2025 If you have the new GD&T engine, you can do Common Datums. Otherwise, in this case, I'd probably just use a Symmetry Plane (not Symmetry). Link to comment Share on other sites More sharing options...
[Do...] Posted May 7, 2025 Author Share Posted May 7, 2025 Please sign in to view this quote. I do not have teh new GD&T engine, unfortunately. I will use the Symmetry Plane option. Thanks for your help clarifying it. Link to comment Share on other sites More sharing options...
[Ma...] Posted May 7, 2025 Share Posted May 7, 2025 Please sign in to view this username. Â wouldn't be there any problems within symmetry plane when uneven number of points and location? I always used that sym plane with same opposing points. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 7, 2025 Share Posted May 7, 2025 Please sign in to view this quote. Please sign in to view this username.  I was unaware of those issues, but if that is a known issue, then I wouldn't recommend it then. Lol. You could either then use Symmetry from each individual plane, or you could leverage Free-Form. Link to comment Share on other sites More sharing options...
[Ma...] Posted May 7, 2025 Share Posted May 7, 2025 Please sign in to view this username.  I am not sure if there are any problems, so i asked. I think i need some testing - i hope i'll find some time for that 🙂 Link to comment Share on other sites More sharing options...
[Je...] Posted May 8, 2025 Share Posted May 8, 2025 Please sign in to view this quote. You are right, when talking about the two-point-distance. LSQ and (in this case) Maximum Inscribed Element should work. 1 Link to comment Share on other sites More sharing options...
[Je...] Posted May 8, 2025 Share Posted May 8, 2025 Please sign in to view this quote. Minimum Circumscribed I mean of course, sry Link to comment Share on other sites More sharing options...
