Creating a plane offset and joining two planes for alignment
Hello everybody,
So, I have to create a plane (Datum B) and send it 3mm theoretically to Z, and join it with Datum A which is 3mm above the Datum B.
What is the best way to create this alignment?
thanks in advance
You can use stepped plane ( i hope it's named like that ) where you have to use 3 points and you declare their position in vector direction.
Or i think you can use geometry bestfit with those two planes and then create theoretical plane with this alignment.
Hello, Interesting !
A quick question about the Knowledge base : there is no summary with all the topics, we have to search manually for each problem?
Correct - You must search. There are categories, but they are broad, so there are many articles per category, so it is best to search.
