[Fu...] Posted May 15, 2025 Share Posted May 15, 2025 Hi, I am fairly new to PCM and I am looking to report a volume measurement on a report. What would be the best way to do this? Link to comment Share on other sites More sharing options...
[Ch...] Posted May 15, 2025 Share Posted May 15, 2025 the volume of what specifically, a sphere? cylinder ? Select Size>Result Element> right click in field and type in your formula. To get 'actuals' from a measured feature use : getActual("Feature Name").x or .y or .z or .diameter, .radius , .length Link to comment Share on other sites More sharing options...
[DW...] Posted May 15, 2025 Share Posted May 15, 2025 Please sign in to view this quote. Please sign in to view this username. There is no calculate volume option like there is in Zeiss Inspect. You will have to set up a result element that does the math for you. 1 Link to comment Share on other sites More sharing options...
[Fu...] Posted May 15, 2025 Author Share Posted May 15, 2025 This is for a cylinder. Thanks for the input I will give this a try! Link to comment Share on other sites More sharing options...
