PCM report volume
the volume of what specifically, a sphere? cylinder ?
Select Size>Result Element> right click in field and type in your formula.
To get 'actuals' from a measured feature use : getActual("Feature Name").x  or .y or .z or .diameter, .radius , .length
 There is no calculate volume option like there is in Zeiss Inspect. You will have to set up a result element that does the math for you.
