[An...] Posted May 15, 2025 Share Posted May 15, 2025 Hallo Zusammen, ich jeweils 3 halbe Zylinder gemessen und möchte nun an diese eine theoretische Ebene "anlegen". Geht dies über Calypso, und wenn ja, wie? Viele Grüße Andreas Link to comment Share on other sites More sharing options...
[Cl...] Posted May 15, 2025 Share Posted May 15, 2025 (edited) Without knowing exactly what you want to achieve. I would start with this. Open a plane (Ebene) feature. Click on "Options" Theoretical Feature. Enter the XYZ coordinates you need. The length1/Length2. The A1/A2 angles. The space axis. Edited May 15, 2025 Link to comment Share on other sites More sharing options...
[An...] Posted May 15, 2025 Author Share Posted May 15, 2025 Imagine you have 3 half cylinders and place them with the flat side on the granite so that the semicircular curvature points upwards. I would now like to stretch a plane over all three semicircular curvatures of the cylinders. As if I were to place a plate on the cylinders from above! Link to comment Share on other sites More sharing options...
[Lu...] Posted May 15, 2025 Share Posted May 15, 2025 (edited) You might be able to do this with formulas, using points that recall each cylinder's x y and z center, then add the actual radius to the z (or whichever direction the cylinders are facing) then create a theoretical plane that recalls the points created. You would probably want to have 2 points for each cylinder though at different points along the length of the cylinder. If you would like, I can go into more detail. I am new to calypso so there is probably a much better way to to this, which smarter people than me probably help you out with, just wanted to give my first idea. Edited May 15, 2025 Link to comment Share on other sites More sharing options...
[Ma...] Posted May 15, 2025 Share Posted May 15, 2025 It should work with plane - recall measured points from all cylinders and use tangential evaluation. Link to comment Share on other sites More sharing options...
