[Sa...] Posted May 19, 2025 Share Posted May 19, 2025 In a project, I have two RPS alignments: one main alignment used for all inspection calculations, and another RPS alignment that I only use for surface comparison. The problem is that when I measure with Kiosk, the DMO generated from the inspection is done with the incorrect alignment. When creating the kiosk template, I have the correct alignment active. Is there any way to fix this? Thank you!! Link to comment Share on other sites More sharing options...
[Na...] Posted July 1, 2025 Share Posted July 1, 2025 Hello Santiago, there is a section "ResultAlignment" in the kiosk config file. As described, a project keyword might also be used. Another solution might be to use an export via file -> export -> report -> inspection in the custom patch. It will use the alignment used on the selected report page. Please sign in to view this quote. Nanno Link to comment Share on other sites More sharing options...
